Carpo Posted February 1, 2018 Report Share Posted February 1, 2018 Think I´ll will buy a FLX S24 in the near future for my small mobile disco. I just have a simple question. Can I program a single bar with one DMX address and four spots so all four spots are working with the effect generator and can be controlled as four individual spots? I am using the fixture in 14 channel mode - ch. 1: Red, ch 2: green, ch. 3: blue, ch 4: red, ch 5: green, ch.: 6 blue, ch. 7 red....... and so on. Ch 13: strobe, ch 14: dimmer. Hope somebody can help me with a solution. Regards. Carsten Poulsen, Carpo Roadshow www.carpo.dk Quote Carsten Poulsen Carpo Roadshow www.carpo.dk Link to comment Share on other sites More sharing options...
kgallen Posted February 1, 2018 Report Share Posted February 1, 2018 (OP - please ignore this comment for now please see Jon's query below). Well if you want individual control of each spot, then each spot needs a unique DMX start address. For example spot 1 is DMX=1, spot 2 is DMX=15, spot 3 is DMX=29, spot 4 is DMX=43 - or any addresses that are separated by at least 14 because your spots need 14 addresses in their 14 channel mode. No spot can have a start address above 499 because all 14 addresses need to fit within DMX channel numbers up to 512. If you give them all the same DMX address they will all do the same thing as they are seeing and responding to the same instructions. Have I understood your question correctly? Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 1, 2018 Report Share Posted February 1, 2018 Hi Carpo, Please can you let us know exactly which fixture you are using? Many thanks, Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
kgallen Posted February 1, 2018 Report Share Posted February 1, 2018 Ah ok, I see, it's a multifixture/composite bar. Good clarification, Jon.... Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 1, 2018 Report Share Posted February 1, 2018 (I opened this thread before you replied Kevin, but didn't actually get around to replying until after you commented, so hadn't seen what you had said!) Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Carpo Posted February 2, 2018 Author Report Share Posted February 2, 2018 20 hours ago, Jon Hole said: Hi Carpo, Please can you let us know exactly which fixture you are using? Many thanks, Jon Hi Jon, Yes, it is a Stairville CLB4 compact bar running in 14 channel mode. I have attached the manual as a pdf Stairville CLB4 Bar manual.pdf Quote Carsten Poulsen Carpo Roadshow www.carpo.dk Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 5, 2018 Report Share Posted February 5, 2018 Hi Carpo, Please find attached the fixture file for the Stairville CLB4 in all channel modes. For 14 Channel mode, Patch 4 of the 3 channel mode fixtures, which will give you a fixture per LED PAR on the bar. In addition to this, patch the "Control" fixture after the four 3 Channel fixtures, to give you an overall Master and Strobe control. Stairville Compact LED-Bar 4.ift Hope that helps, any queries let me know. Kind regards Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Carpo Posted February 7, 2018 Author Report Share Posted February 7, 2018 Great - thank you for the help. I´ll come back with more fixture request in the near future :-) Quote Carsten Poulsen Carpo Roadshow www.carpo.dk Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 7, 2018 Report Share Posted February 7, 2018 3 hours ago, Carpo said: Great - thank you for the help. I´ll come back with more fixture request in the near future :-) No worries. In future, feel free to use our dedicated fixture email address for fixture requests... FixtureSupport@zero88.com This mailbox is checked regularly by the team, so you may get a response quicker than on the forum. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
