Guest Jon Collins
Moving Lights in Playbacks
Guest Jon Collins
I've recorded some moving lights into some playbacks on the FLS S24. When I bring down a playback, the heads return to their home positions. How do I get them to remain in their position, and just the light fade out?
This is because when you drop the fader it "releases" the playback. This means that the playback stops having any control over the lights. If you have no other playbacks active then there is nothing else controlling the lights, so given they have to have "some" position, then the desk will drop back to the fixture default - which is the same as Home but with zero intensity.
What you need to do is to stop the action of lowering the fader from releasing the channels. On FLX this will be Setup+PB button then under Raise and Lower, turn off Release. I suspect FLX S will be the same.
If not, Edward will be along any moment to put the story straight, but this information might get you going in the interim...!
Kevin
Hi Jon,
To do that you need to disable "Release on Lower" for that Playback. To do this hold SETUP and tap the Playback's button to enter its settings. Then tap the "Raise & Lower" tab, and tap "Disable Release On Lower". That way the Playback will leave them in Position, but the fader will be able to take down the intensity.
To then manually release (or turn off) this Playback so that the movers return to their home position, hold CLEAR and tap the Playback's button.
Kevin
Haha just beat me to it!
Hey - you're never that quick on my questions! :P
Edward's answer is much better than mine, though - he uses the correct terminology!
Guest Jon Collins
Thanks... Hmmm, sort of works. If the PB contains an effect, it obviously stays running, but still returns home?
Can you look at my show file?
BW JonCTCRM1.isf
CTCRM1.isf
BW JonCTCRM1.isf
CTCRM1.isf
Hi Jon,
Playbacks 8 & 9 have got "Fader Controls Position" enabled. This means position will always be scaled by the fader. Therefore when the fader is at 0%, they will be in their previous position, whether that be from another Playback or their home position. Therefore disable fader controls position on Playbacks 8 & 9 in their settings. To enter a Playback's Settings as described above hold SETUP and tap the Playback's button.
If you then don't wish to see the fixtures snap to their new position, you can set a fade on this move by holding VIEW and tapping the Playback's button, and tapping the position fade cell and use the encoders to set it.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
