thierry Posted January 11, 2018 Report Share Posted January 11, 2018 Hi everyone, and firstable : happy new year !! Here's the problem : i've updated the system to 7.9.3 Since i've done this, my old playbacks are not reacting the same way : when i raise a fader, it's not dimming smoothly as before, but instead i have a kind of graduated levels of intensity. (only with playbacks of LED fixtures, not with traditional halogen fixtures) I didn't found why, so i've downgraded to 7.9.2.5 and that's ok now Any idea ? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 11, 2018 Report Share Posted January 11, 2018 Hi Thierry, Happy New Year! Hmm that's odd. I haven't seen this before. Would you be able to email me your show file that the graduated intensity is present in? If you could let me know which Playback is causing problems, I'll be able to see if I can replicate the issue. Kind regards Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
thierry Posted January 11, 2018 Author Report Share Posted January 11, 2018 Hi Edward and thank you for your mail. So i have updated again to 7.9.3 and reloaded my show. You were right, RigSync was enabled (i don't remember having touched anything about this, i don't even know what it's made for...). I have disabled RigSync and everything is fine now. You rule !!! Thanks for all, regards Thierry Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 11, 2018 Report Share Posted January 11, 2018 51 minutes ago, thierry said: Hi Edward and thank you for your mail. So i have updated again to 7.9.3 and reloaded my show. You were right, RigSync was enabled (i don't remember having touched anything about this, i don't even know what it's made for...). I have disabled RigSync and everything is fine now. You rule !!! Thanks for all, regards Thierry Hi Thierry, Great glad that solved it! You can find out what RigSync is be reading the article here...http://support.zero88.com/Consoles/FLX/995963301/What-is-RigSync.htm Kind regards Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
thierry Posted January 12, 2018 Author Report Share Posted January 12, 2018 Hi Edward, I have read yesterday the same link and the link with the compatible fixtures. Unfortunatly, even if i own 4 Robe Robin600E wich are compatible, my other fixtures (LinearLeds 36x10W RGBW from Linear technologie) are not, so the option "RigSync" has to stay disabled, if i've well understood everything. Thank you again, regards Thierry Quote Link to comment Share on other sites More sharing options...
kgallen Posted January 12, 2018 Report Share Posted January 12, 2018 Hi Thierry, A Happy New Year to you too! 32 minutes ago, thierry said: Unfortunatly, even if i own 4 Robe Robin600E wich are compatible, my other fixtures (LinearLeds 36x10W RGBW from Linear technologie) are not, so the option "RigSync" has to stay disabled, if i've well understood everything. In the thread below, Jon suggests a workaround for a DMX Universe with fixtures who do not behave in the presence of RDM packets. See the section on DMX address: Regards, Kevin Quote Link to comment Share on other sites More sharing options...
thierry Posted January 12, 2018 Author Report Share Posted January 12, 2018 Hi Kgallen, I think i've understood, but in the room where i'm working there's only one "DMX" cable connected to a splitter far away in an other room, then several "DMX" cables are dispatched where i need them. It's not physically possible (well, very complicated...) to install a second even a third cable, so that i could use several universes. I'm obliged to work like this and i can't do nothing about, 1 Universe and that's all, and with 1 Universe : no "workaround" , and with no "workaround" : no "RigSync" Regards, Thierry Quote Link to comment Share on other sites More sharing options...
kgallen Posted January 12, 2018 Report Share Posted January 12, 2018 Hi Thierry, 22 minutes ago, thierry said: It's not physically possible (well, very complicated...) to install a second even a third cable, so that i could use several universes. It's not about more cables/Universes, it's about patching your non-compliant fixtures at DMX addresses above 32 (or above 257) on the one universe you have installed. However I see you've listed some fixtures (LinearLeds 36x10W RGBW) that I'm sure gobble up DMX addresses so you may not have enough addresses from 257-512 to do this. Also you might not want to get involved in RDM fixture configuration if you have a stable setup using manual configuration that is working perfectly well (i.e. not using technology for technology's sake!). All the best. Kevin Quote Link to comment Share on other sites More sharing options...
thierry Posted January 12, 2018 Author Report Share Posted January 12, 2018 25 minutes ago, kgallen said: However I see you've listed some fixtures (LinearLeds 36x10W RGBW) that I'm sure gobble up DMX addresses so you may not have enough addresses from 257-512 to do this. Also you might not want to get involved in RDM fixture configuration if you have a stable setup using manual configuration that is working perfectly well (i.e. not using technology for technology's sake!) That's it !!! And I have 10 Selecon PLCYC2 too, and i don't want to "re-address" & "re-patch" all. My setup is stable, i keep it like this. too much technology "kills" technology Regards, Thierry Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted January 30, 2018 Report Share Posted January 30, 2018 On 1/12/2018 at 10:31 AM, thierry said: too much poorly-implemented technology "kills" well-implemented technology I'd argue it's closer to this statement Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
