Ovidijus Posted September 13, 2017 Report Share Posted September 13, 2017 If I record some position palletes on a fader as a cue list, without intensity they wont work. Nothing happens. I would like to use one fader for intensity, second for positions. Second fader for possitions should work without intensity, so i could change position in dark. What could i miss? Latest zero os on solution Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 13, 2017 Report Share Posted September 13, 2017 Hi Ovidijus, To record positions onto Playbacks without intensity you will need to ensure SmartTag is off. To do this, when you press RECORD to program your first position without intensity, tap the "SmartTag" soft button in the Record Options popup. You will find your position is now saved with no intensity. SmartTag will now remain disabled until you enable it again in the same way. Hope that helps, any queries let me know. Kind regards Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Ovidijus Posted September 15, 2017 Author Report Share Posted September 15, 2017 Thanks, that did the trick If I record only effect on playback, and set it up to controol it by fader. It controls size and speed at the same time, is it possible to control only size or speed? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 15, 2017 Report Share Posted September 15, 2017 Hi Ovidijus, Currently there isn't a way of a Playback controlling Size/Speed separately when Fader Controls Effect. What you could do however is program a Macro that select the fixtures within a Playback and goes to the effect attribute. You can then trigger this Macro from the Playback, which will then allow for live effect control on the encoders. There is a plan for the effects engine to be updated which will allow for separate Speed/size control on faders, however currently there isn't a time frame for this. Hope that helps. Kind regards Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Ovidijus Posted September 16, 2017 Author Report Share Posted September 16, 2017 Thanks Quote Link to comment Share on other sites More sharing options...
