Sign in to follow this
AdamW
Unable to record Fan Effect
I'm creating an effect with some movers. I put them in Figure 8 and then I use SHIFT+Speed to create and fan first offset.
The lights are now randomly moving around which is what I want.
However, when I record the cue it completely forgets the offset.
It will remember literally every attribute (speed, tilt, pan, size...) but it will not remember the Fan option.
This means when I go back into the cue, the lights will all be moving in perfect time with each other, instead of randomly like I want them to.
I've tried pretty much every combination of record options (smart tag on/off, tracking on/off, snapshot, shift+record, and every other option available in the pop up window)
Any help is greatly appreciated.
Hi Adam,
What software version are you running on your Orb?
I believe this was a bug in ZerOS 7.8.2.36, and so I recommend you using the latest software (ZerOS 7.9.2).
Create an account
Register a new account
Sign in
