RCRLIGHTING
FAT FROG - Help Creating Fixture Profile
Hello All,
I have 4 GLOW-LIGHTING Bumble Beams which in short is a Chinese knockoff of a Clay Paky Sharpy. I have tried using the Sharp Standard and Vector Profiles which seems to work...sort of. I tried to create a fixture profile but can't seem to get the configuration correct. Any help would be great.
Manual attached in zip form
Thank you in advance for your time.
Reg
Bumble-Beamâ„¢-User-Guide.zip
Reg, Can you post your profile file - at least that gives us a starting point, and when you get it back you can see how it was adjusted.
Kevin
Evening Kevin, hope all is well.
Here it is. Pretty close to the Sharpy profile but still a no go. One thing i noticed, when I create a chase, the fixture do a 360 spin before the chase is executed. Not sure if this info helps.
Hope this helps.
R
Sharpy_Clone.ift
Hi Reg,
I had a quick look at your profile in the Fixture Tools and it looks superficially ok (I didn't check against the manual).
I notice you haven't allocated any wheels to any function - you say in your title that it's for Fat Frog, so you'd need to allocate each parameter within the "3-Wheel Groups" tab.
I've assigned these in the attached. You might want to edit this profile and group them a little more to your liking! Note there are multiple pages of Beamshape so you'll need to press the Beamshape button to cycle through the pages to get the required parameter available on a wheel.
Let me know if it's still broken or this wasn't the problem you had (I've never tried it but its possible the Fat Frog will auto-allocate wheels if the fixture doesn't define them!).
Re the 360 spin - this sounds like either a programming problem or maybe the HOME value for pan is not the "dead centre" position? Or maybe the MSB/LSB is the wrong way round for the 16-bit parameters pan/tilt (sorry didn't check the manual).
Kevin
Sharpy_Clone_v2.ift
You're right - all consoles will auto-allocate the encoders if they aren't defined. The wheel groups just give you more control (one of the main reasons I use them is to have the same parameter on multiple pages - for example focus)
Ah so that's my bright idea for the problem banged to rights then! Reg, if my revised profile is still no good then we need to look deeper!
Give this a go - I've not changed much, a few defaults etc.
If that dosn't work, I'd suggest the manual is wrong - it's not unusual for cheap copied fixtures to have poor incorrect documentation
Sharpy_Clone.ift
Create an account
Register a new account
Sign in
