Sign in to follow this
phil at hayling
LED colour change times on solution
Hi
I am an occasional touring user of the Solution and hit a snag with some LED PARS and profiles.
These were changing colour in zero time, whilst changing intensity at the required rate. Obviously when they went to black between cues, no problem because they changed when dark.
As far as I can tell this time could be set up in the desk parameters, although it is not obvious which one.
However having found the problem, sorting it out by editing is something that I could not do, although I am sure that there is a way.
Can anyone enlighten?
Thanks.
If you have programmed the LEDs in a cue stack and the colours are snapping when go is pressed and intensity fading, it sounds like you need to go over to the Colour Fade field in the cue stack table for that particular cue, and edit the colour time to the same time as the cue fade time, for example all fades for the cue of 3 seconds.
In setup the default should be a colour fade of 3 seconds, but this could have been changed, resulting in a colour fade default of a snap.
Hope this helps and answers your query.
Ed's correct - you need to change the Colour fade time. On Solution, we show the fade time of whichever attribute is currently selected (Colour, Beamshape or Position) so press "Colour" and you'll see the colour fadetimes appear in the Cue List.
Create an account
Register a new account
Sign in
