charliez Posted June 29, 2016 Report Share Posted June 29, 2016 When I try to live edit a memory, fade up the sub master fader. For example add one more peset channel into this memory. Fade up the preset fader, press record button and click merge. Then press clear button. Now if you fade down the preset, the preset fade will grab the output. Is there any way, after merge the memory and press the clear will release the preset fader. Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted June 29, 2016 Report Share Posted June 29, 2016 Press clear twice once you have lowered the preset fader. Quote Link to comment Share on other sites More sharing options...
charliez Posted June 30, 2016 Author Report Share Posted June 30, 2016 Press clear twice once you have lowered the preset fader. Yes i did twice, even more, it would not help. i think this is very common when people wants to live edit a memory, after record the change, double click clear for clearing the programmer, when you lower down the preset fader, it will grab the output..... Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted June 30, 2016 Report Share Posted June 30, 2016 You need to lower the fader first before pressing clear. Or change your desk behaviour to htp rather than ltp Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted June 30, 2016 Report Share Posted June 30, 2016 just in case: to change the desk so it works in HTP, press [setup] to enter the setup screens, select [desk setup] at the bottom of the screen, then [behavior] at the top of the screen, here you will see an option called 'preset mix mode' change this to HTP (i suspect it will be on the default of LTP) HTP will always take the highest intensity value as the priority eliminating the problem of your preset catching the memory value. although this can present its own problems. Quote Link to comment Share on other sites More sharing options...
