charliez Posted June 24, 2016 Report Share Posted June 24, 2016 i tried to patch dimmer 1 thru 5 to a DMX channel like 20, how to do that? i went through forum and user manual, could not get the right answer. i only saw duplication which is patch one fixture into multi DMX address? if someone can point out where i should look at, thanks a lot. Quote Link to comment Share on other sites More sharing options...
ziglight Posted June 24, 2016 Report Share Posted June 24, 2016 hello go to SETUP- Edit Fixtures - Patch select channel 20 (for exemple Shift+Flash-Button) change DMX address from 20 to 1 (if initial patch was 1:1...) then click add to add other DMX addresses (2 to 5 in your example) -> Duplicate1, Duplicate2, Duplicate3..... etc etc.... Quote Link to comment Share on other sites More sharing options...
charliez Posted June 24, 2016 Author Report Share Posted June 24, 2016 Thanks ziglight, you are so helpful Quote Link to comment Share on other sites More sharing options...
