keredyelesob Posted May 13, 2016 Report Posted May 13, 2016 Hi Not sure if this is a bug or just intentional, but; say you have a chase recorded in cue stack 1 and then your show in cue stack 0, you have some cues in CS0 that trigger and release your chase in CS1. If i then delete my chase in CS1 all of the references for the triggers and releases are left behind, should this not delete all references to CS1? I can see advantages and disadvantage of leaving references, for instance; an advantage would be if you where deleting the chase to replace with a new one, you may want the triggers to remain in place, however a disadvantage would be if you are deleting the chase in CS1 to replace with a manually operated scene, in this case you would want all triggers to CS1 to be deleted with the stack to avaid accidentally running the scene In a similar scenario are the macros, however this works on the principle if you delete the macro all reference to that macro are deleted with it. Again i see the same advantages and disadvantage with macros and i do with cue stacks. Anyhow like i say not sure if its a bug or not, just thought i would ask.
Jon Hole Posted May 16, 2016 Report Posted May 16, 2016 Hiya, Not a bug, but definitely something we could improve in the future! I've added this as a comment to ZOS-6105 which relates to integrating triggered Playbacks with the Playback which triggered them. Jon Hole linkedin.com/in/jonhole
