Submaster Rec.
If have a Orb with Latest software.
I put the dish fader mode into channel mode.
open channel 1 true 10, press record sub 10.
Now sub 10 is recorded but no Intensity of channel 1 true 10 is recorded.
I have tried all different options but no result except snapshot but then the risk that al moving head go to there home position if i open this submaster.
I hope i should be able to record just the intensity of channel 1 true 10 ??? Right ??
Records Vincent
Hi Vincent,
I think it's probably getting confusing because you're using the faders as both channel faders and submasters. It's not a problem, we just need to make sure you're doing the right process:
Just to confirm, are you doing exactly the following:
1) Press "Fader Function", choose "Channels", choose "1-60"
2) Push up the first 10 faders
3) Press "Record Sub 1 Enter"
4) Pull down the first 10 faders
5) Press "CLEAR" twice
6) Press "Fader Function", choose "Submasters"
7) Push up the first fader - you should see Channels 1 - 10 come on to full
Create an account
Register a new account
Sign in
