daniloT
chase manuel on fader
To make a chase on ORB XF, you need to use a Cue Stack. These can be set to the bottom 20 faders using the "Fader Function" button. Record each step of the chase as a separate cue. You then choose "Stack Setup" (or hold SETUP and press the fader's flash button), choose "chase" in the window that popups, and then choose "Turn into chase".
I am having a similar problem. I have it in a stack and changed it into a chase how do I record this into one of the subs on the bottom row?
Create an account
Register a new account
Sign in
