Massimo St Posted February 17, 2015 Report Share Posted February 17, 2015 Hello every body, Is it possible to edit the speed of a active chaser with the submaster or a preset fader? For live controling would it be very confortable.Massimo Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 17, 2015 Report Share Posted February 17, 2015 Hi Massimo, You can set the chase to "beat" inside the submaster setup window, and then use the step button to change the speed (you press it twice in time with the beat, and the chase will continue at that speed) Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Massimo St Posted February 18, 2015 Author Report Share Posted February 18, 2015 Hi Jon! Thank you ! It runs very nice! But now my next problem: I have normal LED PAR's with a parameter for the Intensity. Now i want to create a chaser, which only changes the intensity. But it does not work. Whats the problem ? Regards from Switzerland Massimo Quote Link to comment Share on other sites More sharing options...
KWR88 Posted February 19, 2015 Report Share Posted February 19, 2015 Hi Massimo, Who's make of LED are you using? Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
