hafashah Posted February 11, 2015 Report Share Posted February 11, 2015 . Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted February 11, 2015 Report Share Posted February 11, 2015 As far as i know there is no direct way to do this. If your SM only contains 1 scene you can load the SM you want to copy into the programmer and then record it to the memory. Or anoth method i have used in the past iis just play back the SM then record the memory (you will need smart tag enabled for this method to work) Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted February 13, 2015 Report Share Posted February 13, 2015 Or anoth method i have used in the past iis just play back the SM then record the memory (you will need smart tag enabled for this method to work) This is what I do too :-) Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
hafashah Posted March 3, 2015 Author Report Share Posted March 3, 2015 that worked well , thank you Quote Link to comment Share on other sites More sharing options...
