Sign in to follow this
Simonkbike
Can't see User Fixture file
Any reason why my Solution can't find a fixture file on my USB stick?
I adapted a fixture file to create one for a LEDJ Alu Par 64. Put it on the same USB stick I used to backup show files. When I try to load the file it doesn't show up.
File attached. LEDJ DMX spec is at prolight.co.uk/images/media/LEDJ110/LEDJ110-um0.pdf
Any suggestions?
S,
Sorry, not sure if this should be here or in Fixtures section.
LEDJ ALU PAR 64.ift
Hiya,
I can't see anything wrong with your fixture file so as long as you are loading the user fixture type (UFT) file as per page 61 of the manual then you should be Ok
Regards
Mike
Create an account
Register a new account
Sign in
