1-48 faders flash button mode
cycy
Hi,
You can change this setting by pressing 'Special' and then choosing 'Flash Mode' on the Multi-Functional Keys (MFKs). It should be on the top row, third button along.
You now get the choice between Flash, Solo, Latch and Off / Select.
This shouldn't have changed with the latest software, and we default on 'Flash', so it suggests someone has changed this setting.
When you say on/off - do you mean the light itself, or just the LED on the flash button? If the latter, that means that channel has been selected. This happens when the flash mode is set to 'Off / Select' or you press the flash button whilst holding SHIFT, which could suggest your SHIFT button is stuck down (or being pressed down on an external keyboard maybe?).
Best regards
Jon
Jon Hole
