Paul SWAV Report post Posted January 30, 2014 Hi I'm a repair tech at a company that sets up concerts, events etc. I see some posts kind of similar, but not quite. Our Fat Frog lights up briefly & won't start, no lcd display, intermittently. I plug it in, all the leds and lights flash on briefly, then go off. Most of the time it will work. One time it got stuck loading at 44% and froze. V.10.12.1 I tried tightening all the connectors, and cleaning the contacts on the memory cards, Since it is so random, I don't know if it helped yet, but any feedback would be appreciated Thank you Paul Share this post Link to post Share on other sites
iank99 Report post Posted January 30, 2014 If you know the battery on the mainboard is ok then it might be bad news, the mainboard itself might have failed. However it would be worth swapping the battery to see if that makes a difference (but usually the desk will power up and simply not retain memories) so I suspect it may be more than that. If you have one about, try swapping PSU's (or if you have a Jester PSU then it should power a Fat Frog). Share this post Link to post Share on other sites
Paul SWAV Report post Posted January 30, 2014 The battery is still holding full charge, and tried another supply. Thank you Paul Share this post Link to post Share on other sites
KWR88 Report post Posted January 31, 2014 Hi Paul, You have mailed me direct on this as well so will continue with this from there. Share this post Link to post Share on other sites
