ML48 Can't edit submenus
CHIPS
Ihave used this desk in the past and edited scenes in various ways successfully. For simplicity the current show is programmed as scenes in the submasters ( timing being entirely unpredictable at time of writing). Al attempts to edit these scenes are failing. The process appears to be working but the scenes emerge unchanged. I have checked on the Phantom to ensure that my procedures are correct and that works. I have now made changes in phantom and loaded that as the show but there are some colour balances I can only get right visually and the board will not let me. Before I record the board as malfunctioning is there anything I should try. Show is tonight and I intend to be well Coffeed up and deal with problems on the hoof. How i miss "top set"
To edit a sub if you go into run and play it back then jump to program with it active it will be outputting the channels info. Make the change then re-program the sub you want and over write it. then go back to run again.
Keith Rogers
