Sign in to follow this
NickTaylor
UDF settings
I am using the desk on a show this week. third time out but oddly the first time I have actually run a show with it.
My question is. What should I have set on the UDF for the following scenario.
I have a playback main stack. the show has LEDS and Mac 250s all programmed in and working fine. However I want to manually add two thrust stage areas (conventional lights), up and down as required. The problam is at the end of the manual part on pressing next on the master output the thrusts if on at all surge to 100 % and then fade. My workround has been to decide the maximum I require for the lighting on thrusts and set the UDF at say 60%. Then when I press next on the master they dont flash up but fade with the rest of the lighting. I have tried all the LTP and HTP settings, but with no luck. Any ideas chaps?
Create an account
Register a new account
Sign in
