Smoke problem
coombesy85
Do you have any more information on the DMX control of the smoke machine ?
Would I be correct in assuming that it is controlled by a single DMX channel ?
If this is the case then you should be able to control it with the preset fader representing desk channel 48 (patched to DMX channel 89).
:idea: The desk will need to be in Wide mode
Bran Media | Myspace
Try checking the Preset Control button, the associated LEDs and the position of the A Master and B Master faders.
In Wide mode, there are two 'scenes' - one defined by the preset faders and the other stored scene. The outputs of the two 'scenes' are controlled by the A and B master faders and the Preset Control button determines which fader controls which scene.
