Sven76 Posted October 18, 2011 Report Posted October 18, 2011 Hello everybody, I have a problem with saving things to Palettes. I don't know, if it is a problem with phantom only, because I don't have the Leap Frog here, at the moment. Here is, what I tried: - Select a Fixture (I tried with a MAC 250 Entour) - change the Pan/Tilt Position with the Encoders (Programmer and DMX output show the right behavior) - Select the Position MFKs - Press and hold a free MFK for some seconds - clear the programmer After those steps, I can't use the stored Position. It even looks wrong on the Palettes Screen on my Monitor. the default Position, which is available looks like 1 P [Home Position] and is marked as "Available" The new "Button" looks like 2 Position 2 and is marked as "Not Available" So it even don't recognize the right Attribute :-( Could anybody tell me, what 'm doing wrong? Kind regards Sven
Kirkup_xp Posted October 18, 2011 Report Posted October 18, 2011 Hi Sven Are you in non-tracking mode? In non-tracking mode, or with Smart Tag enabled in Tracking Mode, the desk looks at fixtures whose intensity is set to 0% and ignores any other values set for those parameters. This is to simplify programming of complicated cue stacks where you don't have to 'think' about fixtures whose intensity is 0%, but can cause some confusion when programming palettes. Try setting the intensity to 100% on the fixtures before you program the palette. Note that this will not get stored into the palette, but just needs to be turned on before you program those fixtures. I hope that this helps - please let me know how you get on, Peter Peter Kirkup
Sven76 Posted October 19, 2011 Author Report Posted October 19, 2011 Hi Peter, thank you for that hint! That was the information, I was missing ;-) It works perfekt, now! Kind regards Sven
