Add Fixture using USB on Phantom
Visironer
Tested this out and do not seem to have an issue loading fixtures into the phantom desk.
Check the path to where it will search is correct in the settings menu.
If you had it mapped to the USB port when a USB drive is plugged in make sure it is the same port the USB is generating when you plug it in now or update the path to drive match it.
Regards,
Keith Rogers
keith.rogers@signify.com
DD: +44 (0) 1633 833 101.
