Sign in to follow this
Kirkup_xp
Zero 88 Launch Solution Console
Launched at PLASA 2011 was Zero 88’s new range of multipurpose lighting control consoles, the Solution and Solution XL.
Running the powerful new ZerOS 7 operating software, the Solution Series offers comprehensive hands on control of conventional generic channels, submaster and cue stack playback and moving light controls, all laid out in an easy to use, familiar fashion. The consoles feature four DMX universes, USB storage, external touch screen support, multiple onboard LCD displays and multifunctional keys (MFKs).
Whether you require a solution for simple shows or major professional productions, the Solution Series is flexible and configurable to provide the controls you need when you need them. Designed to be easy to understand, yet adaptable enough to cope with even the largest lighting systems, the Solution Series make controlling your entire system as easy as turning on your house lights.
Simple:
Solution Series provide a simple, clear progression from basic two preset generic control through to moving light and LED control. Hands on control with submasters and channel faders combine with a powerful theatre stack to facilitate any type of show.
• Channel faders for hands on control
• LCDs for clear easy to read information display
• Wizard driven patching to guide you through the process
• Full online help
Flexible:
The flexible front panel with cue stack, submasters and live controls allow the Solution Series to be adapted to multipurpose venues where the requirements change daily. From simple moving light patching to powerful offset effects, the Solution Series has been designed with flexibility at its core.
• Advanced fixture library with over 2600 fixtures
• Remote applications for wireless control
• Rate control, tap tempo and sound to light chases
• Move on Dark for cue lists
Professional:
Featuring ZerOS 7 software, the Solution Series offer powerful adjustment of complex effects, a tracking cue stack and adjustable user preferences to enable full professional programming options. Advanced palette references, tracking updates and remote tracking backup options mean you can rely on the Solution Series to grow as your requirements do.
• Support for all major visualisation packages
• Ethernet output of DMX
• Fully enabled Remote Device Management (RDM)
With the power of ZerOS 7 and a new modern package the Solution Series is the perfect control solution for corporate, live and theatre events.
To view more information about the Solution Series, check out the main website.
Sorry for the stupid question: I can't see a diferent between the new "solution Series" and the "Leap Frog" series. Could anybody give me a hint?
Kind regards
Sven
As you said, the Leap Frog 48/96 and Solution /XL are identical besides the design, so does this mean every upcoming update for the Solution will also be published for the Leap Frog at the same time?
So regardless of which desk I'm going to buy, will I be able to receive every update? Or are the Solution and Leap Frog series planned to be split for marketing reasons or whatever, so Leap Frog users would only be able to receive bugfixes while Solution users also get additional features in the future?
Thanks
There are minor differences between the two consoles, such as the default view for example.
We can't comment on future software releases, as some of those decisions haven't been made yet, but the ZerOS Software, which runs on both consoles, will be supported and invested in well into the future.
Create an account
Register a new account
Sign in
