fridgeman Posted September 8, 2011 Report Share Posted September 8, 2011 Hi, Wondered if anyone could help ? If you are in run mode and have scene running from the cue stack can you program a submaster in i presume flash mode so it that submaster would overide the cue stack list scene whilst holding your finger down then return to the cue stack scene on release ?? Cliff Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted September 10, 2011 Report Share Posted September 10, 2011 Hi Cliff, If you switch the submasters to 'SOLO" instead of 'FLASH' then only what you program onto that Submaster will be outputted when you hold down the flash key. I think this is what you are looking for? Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
