No dimmer values in program window
derboessl
Hi!
Before installing the release 7 to my desk I´m just testing with the offline software.
1, My program window shows no dimmer values. Is this just a bug in the offline software?
2, The SCREEN button is very useful. But I can´t get the group window to desktop 2 to 5.
I think this doesn´t work because of the SHIFT+GROUP problem that you explained already
in the forum. Is this right?
:-) Stefan
Lighting Designer
Leap Frog 48 / LG1730SF
Hi Stefan
We have changed the Program Window to be more focussed towards programming fixtures from ZerOS 7.0 onwards. The generic channel tag states are still shown in the Output Window, so you can use this window instead to see the information you are looking for. This dedicated fixtures window allows you to see far more fixtures in one view, versus the old version. I hope this makes sense.
To move windows to another screen, you need to have the screen active. So log in with your remote monitor (iPad/Windows/Android) and then select the group window and push 'Screen'. If you are just using the internal desktops, you won't be able to move this screen onto Desktop 2 at present.
I hope this helps,
Peter
Peter Kirkup
Hi Peter,
thank you for the information.
I think the old solution to see the dimmer values in the program window was the better one.
If you modify seq/mem in blind mode you don´t have a quick overview what dimmer channels are programmed.
The option to switch the dimmer channels in the program window on would be nice.
:-) Stefan
Lighting Designer
