paolo Posted May 23, 2011 Report Share Posted May 23, 2011 Sometime, when i modify a scene by edit,some parameters of the fixtures (pan ,tilt,shutter)have a variation(example from 100 to 0) Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 24, 2011 Report Share Posted May 24, 2011 Hi Paolo, Could you email me a show file so we can try and recreate this and help you further? Many Thanks Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
sebm Posted May 6, 2012 Report Share Posted May 6, 2012 Hi, i'm New To this forum. I have an issue on my Fat Frog: Is there a way to run a scene for LED Bars (changing colours) with the Override Regulator without pushing instantly the "Go" Button? Greetings, sebm Quote Link to comment Share on other sites More sharing options...
KWR88 Posted May 8, 2012 Report Share Posted May 8, 2012 It sounds like you want to program a chase into a memory. To do this then follow the steps below. Set the next cue to the one you want to program a chase to and make sure the play back x master is at 0. Press and hold the program button until the memory type changes to chase. Display will show the chase program box with the step number showing a 1* Set up the first colour and press program. Step number movers on to 2* Change the colour to the next one you want and press program again. Step number moves to 3*. Repeat the above until all steps have been programmed. Press the arrow down button to enter the chase modifier section. Take the playback master to full and the chase will start to run. Set direction the chase is running. To fade between the colours you need to set the colour action from snap to fade. Adjust the chase speed pot until the colours are cycling at the desired speed. Note the colour fade is worked out on the speed of the chase. The bottom option is shots this is the number of times the chase will run before stopping, 0 is contantly running, you can then set 1 -255 times. It will always stops on the last programed step. Once all modifiers are set press the enter button to save changes and close the chase box. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
