HobitLight Posted May 13, 2011 Report Share Posted May 13, 2011 Hi guys, On the Leap Frog is it possible to set the programmed LTP values of a submaster to be relative to the level of the submaster? So, for example, a moving head has a manual/ value from the cue stack tilt value of 100, and the submaster has a programmed value of 200, the submaster would set the tilt value to 150 if the submaster is at 50%. I'll pretty sure this isn't possible on the desk, so if not could this be considered for a future update? Many thanks, HobitLight Quote Link to comment Share on other sites More sharing options...
HobitLight Posted May 15, 2011 Author Report Share Posted May 15, 2011 Doh! Having read through the manual I've found that the answer is yes, this is possible! For those searching for this in the future, it's on page 122 of the manual, and called Submaster Controls. Thanks Zero88! Quote Link to comment Share on other sites More sharing options...
