hi,
Does any one know where I can get a power unit for a sirius 24.
Thanks
sirius power unit
Started by wallin6228, Jan 18 2011 10:33 AM
7 replies to this topic
#1
Posted 18 January 2011 - 10:33 AM
#2
Posted 19 January 2011 - 09:34 AM
Hello.
Could you elaborate?
If you are talking about the power supply, the Sirius 24 has an internal power supply PCB. Is this what you are looking for?
Dan.
Dan.
#3
Posted 19 January 2011 - 05:57 PM
yes it is i need the PCB
#4
Posted 20 January 2011 - 09:38 AM
Hi ahain.
The PSU's are not complicated and a repair should be fairly srtaightforward.
Dan.
Dan.
#5
Posted 22 January 2011 - 11:52 AM
hi
after a little more searching i found its the internal battery on the main pcu that has leaked. Does any one know where to get one.
#6
Posted 22 January 2011 - 05:35 PM
Good news... Not the PSU...
Make sure that you clean around the battery and remove all the gunge from the PCB. Any left on the PCB will cause nasties later. I have just had a zero 88 XL in the workshop that had not been cleaned after battery replacement. It was totaly non-functional. After a good clean up and some IC socket and IC replacements it was fine.
CPC, Rapid electronics or RS would be your best bet.
Good luck.
Daniel.
Good luck.
Daniel.
#7
Posted 03 July 2012 - 02:03 AM
Does any one know where to get one?
recommend you Criminal Minds Season 7 DVD,a very good-looking DVD!
#8
Posted 05 July 2012 - 01:37 PM
I normally order them from RS componets number 422-393
see the link below.
http://uk.rs-online....7633D4E4F4E4526
see the link below.
Keith Rogers
Service Manager - Cooper Controls
keith.rogers@cooperindustries.com
DD - +44 (0) 1633 833 101.
Keith Rogers
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
