philzb Posted August 19, 2010 Report Share Posted August 19, 2010 Hi there! I hope to get any help! O just started to work with an Leap ML 48. I added 2 Movinghead as new fixtures. Then I located them on the MFK's to selekt. But I didn't want controll the intensity level by wheel. So I located dem to a preset fader. Then I could controll the intensity level, but nothing else. I couldn't change the colours and gobos ba MFK's anymore. What did I wrong? How can I select the preset chanal on with the moving head is located, for example? Or in anycase: is it possible to controle the Intensity by fader (not only by wheel)? Is it possible to controll the Intensity by fader and wheel in same time? Thanks for any help! Cheers philzb Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted August 20, 2010 Report Share Posted August 20, 2010 Hi Philzb, You need to press 'special', and then 'flash mode' (3rd MFK along the top) and choose 'Off / Select'. You can then use the flash buttons to select the fixtures patched on the channel faders. I hope this helps, Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
philzb Posted August 20, 2010 Author Report Share Posted August 20, 2010 Thanks Jon Hole. I'm gonna try this. Quote Link to comment Share on other sites More sharing options...
Jean-Christophe Posted September 3, 2010 Report Share Posted September 3, 2010 Great Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted September 4, 2010 Report Share Posted September 4, 2010 Hi Guys, Just an update to this - if you need to keep access to the flash buttons, but don't mind using a key combination to select the fixtures, you can keep the flash on, and use SHIFT + Flash Buttons to select. Cheers Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
