Blue Screen of Death
MechTech
I have a LeapFrog that needed a battery replacement. I replaced the battery with a new CR2032, but now I have a couple of problems.
1) after boot up, I have no keyboard capbilities
2) sometimes after hitting the Program button, the system display will show a "blue screen of death" similiar to MS Windows.
With the second issue, I get the following diplayed on the screen:
> in Trap 14 : #PF-PageFault
Current Task: 'Main Task'
Task List:
'KEYBOARD: Sound Handler' : 0x00000000 Trace Stack: [0] Trace Stack End
'OS: Drive Off' : 0x00000000
'SPIL: Data Update Handler' : 0x00000000
'DK-K DMX Task' : 0x00000000
'Main Task' : 0x00000000
Interrupt States
0:0 1:0 2:0 3:0 4:0 5:0 6:0 7:0 8:0 9:0 10:0 11:0 12:0 13:0 14:0 15:0
Upon bootup I have the following:
BIOS v5.3.1 13/9/04 memory 29360128
OS v13.2.10 8/12/05
*DeskID 3 is invalid
Bootloader 'C601 FMV C906
Frog OS 10.4.1
Thank you for you help,
Chris
Sounds like something may be corrupt as the ID3 invalid should not be displayed.
It is worth installing the OS as you are not running the latest version anyway.
It may also be a seating issue with the on board RAM moduel.
May be worth removing and cleaning the edge of it.
It is easier if you use the e-mail address below to contact me if you need any further help.
Regards,
Keith Rogers
