Sign in to follow this
Some Phantom bugs
Just two things i've noticed whilst using Phantom ZerOS (version 5.4.0). Not having used an Orb console in the flesh I am not sure if these problems track through to the actual software running on the console.
1. With smart tag enabled, parked channels get included into the programming.
2. Should you change the type of playback (from a cue stack to a submaster for example) whilst playing back said playback, the cue stack gets 'hidden' but the information continues to output. Meaning the only way to regain control of these channels is to either change the playback back to a cue stack (it reappears, untouched) or to manually knockout the values from the programmer.
Perhaps a dialogue and block to stop this? - "Please clear playback or release cue stack before changing playback type?"
Thank you.
Create an account
Register a new account
Sign in
