Sign in to follow this
lxkev
x spot gobo pallets
Hi Kev
The problem with this fixture is that it has multiple modes that the gobo channel can run in, which are determined by the 'function' channel. As the ORB can't dynamically change these palettes, we can't reliably know that the palettes will work every time so we don't enter that data into the library.
Sorry about this - you could always modify the fixture type to add the data for the mode that you use the fixture in, if that helps?
Peter
Create an account
Register a new account
Sign in
