Carwyn Posted January 13, 2010 Report Share Posted January 13, 2010 is there any way of editing a step of a chase within a Q. HELP!!!!!!! Quote Link to comment Share on other sites More sharing options...
Kirkup_xp Posted January 20, 2010 Report Share Posted January 20, 2010 Hi Carwyn You need to LOAD the step into the program window - press LOAD, select the memory (or sub) and then select the step. Once you press OK you'll see that step and away you go. Make the changes and press UPDATE then OK and the chase will be updated. Hope this helps, Peter Quote Peter Kirkup Link to comment Share on other sites More sharing options...
