smythy75 Posted March 29, 2009 Report Share Posted March 29, 2009 how do i programme a chase on ml24? peter Quote Link to comment Share on other sites More sharing options...
David Chadderton Posted March 30, 2009 Report Share Posted March 30, 2009 Programme the first step exactly as you do a scene. Go back to the same memory and record the second step in the same way. You be warned that you may be about to overwrite an existing memory, but one of the options is 'Make Chase'. Select this and continue to add steps until you've finished. Quote Link to comment Share on other sites More sharing options...
smythy75 Posted April 11, 2009 Author Report Share Posted April 11, 2009 Programme the first step exactly as you do a scene. Go back to the same memory and record the second step in the same way. You be warned that you may be about to overwrite an existing memory, but one of the options is 'Make Chase'. Select this and continue to add steps until you've finished. thank you! so you have to do it step by step but save it in the same location really! peter Quote Link to comment Share on other sites More sharing options...
David Chadderton Posted April 12, 2009 Report Share Posted April 12, 2009 thank you! so you have to do it step by step but save it in the same location really! Exactly right. Good luck! Quote Link to comment Share on other sites More sharing options...
CHIPS Posted November 26, 2011 Report Share Posted November 26, 2011 I have programmed two chases which work well together and transferred them to submasters. They were programmed as sllow and graceful crossfades but revert to "snap" each time I hit a stacked cue - ie in the chase set up window which I have on live I can see the Fade updown revert to "snap". As long as I remember to change this rapidly just before fading up I can manage but there must be a better way. Quote Link to comment Share on other sites More sharing options...
