Sign in to follow this
ramacar
4.4.4
I'm trying to update the Leapfrog 48 to 4.4.4 without success. The board lists the file under "load show" option but does not list the file under "update software" option. I've reformatted the USB drive several times and tried moving the file several times to no avail. What am I missing? Bob
to update the desk you need to first insert the usb in your pc, unzip the file and run the install program on your pc. Then you need to insert the usb in the desk and switch it on! Attention you need to connect a monitor cause the update instructions are only visible on the external monitor!!
Sparky- thanks for the reply. I got the desk updated eventually. My error was moving the file to the USB stick instead of running the installer to load the USB stick. I'm more familiar with the Mac OS and was assuming the move function was like drag and drop. My bad. Thanks again. Bob
Create an account
Register a new account
Sign in
