dmx dead - lightmaster xls
Our venue has an old lightmaster xls which has served well. Several months ago a touring sound engineer plugged in his outboard into the same 4 way that the desk was plugged in and blew the 4 ways fuse. After that dmx stopped working on the desk.
Our dimmers are fine and so is the smoke machine and moving lights. If i hooked up the desk directly to a dmx device it seems not to be recieving dmx.
we purchased a replacement desk (jester ml24) but it would be nice to be able to use the old desk aswell hooked through the jester.
Is this an easy fix?
  • 2 weeks later...
Most likely failure of the DMX driver IC inside the unit.
Should be a reasonably easy fix as the driver is socketed. You should be able to obtain the driver from your local dealer.
Please e-mail me on the address below if you would like any further details.
Keith Rogers
