JAdamson Posted September 3, 2008 Report Share Posted September 3, 2008 To the guys at Zero 88: I have one of the "older" model Fat Frog consoles, and have a question concerning use of newer monitors. What specs should I look for if I were to purchase a new monitor, probably a widescreen unit? For example, is there a secific "native resolution" that the FF prefers? Thanks for your assistance. --John Quote John Adamson Link to comment Share on other sites More sharing options...
Paul Posted September 3, 2008 Report Share Posted September 3, 2008 The Fat Frog outputs in VGA text mode (80x50 visible characters, 640x400 visible pixels, 70Hz frame rate) - this is the default mode used by most PC bioses. You probably won't find this information in many monitor specifications, however we've not come across any monitors that have a problem with the Frog series monitor output. Quote Link to comment Share on other sites More sharing options...
JAdamson Posted September 3, 2008 Author Report Share Posted September 3, 2008 Thanks for that info Paul. Quote John Adamson Link to comment Share on other sites More sharing options...
