Withaar Posted June 18, 2008 Report Share Posted June 18, 2008 I have a XLS and 2 DateQ 603 Analogue 0-10v Dimmer. The XLS uses a Din 8 and the Dimmer a 15 pin connector. The XLS side (picture from the German manual) The dimmer side: 1-6 = channel 1-6, 7=gnd, 8 = 15 Volt out, 9-15 not used. Channel 1-6 is clear 1-6 to 1-6. XLS Pin 8 = 0 V Signal Ground to Dimmer pin 7 = Gnd. But do I need to connect XLS Pin 7 = Power IN, +20 Volts @ 200mA to Dimmer pin 8 = 15 Volt out ? Why power IN and Out and how about the 5 volt difference and what about the 200mA? And 20 volt, 15 volt... where are the 10 volt from 0-10 volt...? Quote Link to comment Share on other sites More sharing options...
Paul Posted June 19, 2008 Report Share Posted June 19, 2008 The XLS does not have any internal connection to Pin 7 on the analogue output DIN connectors - the information in the German manual is incorrect on this point. You only need to connect channels 1-6 and 0V to the dimmer. The correct information is given on the rear panel of the XLS: Quote Link to comment Share on other sites More sharing options...
Withaar Posted June 21, 2008 Author Report Share Posted June 21, 2008 Thanks Quote Link to comment Share on other sites More sharing options...
