sicole Posted March 6, 2008 Report Share Posted March 6, 2008 We have 1 x Betapack3 thats playing up. Unfortunately the customer is 35 miles away and dont relish the prospect of going there to find its goosed and have to go there again to replace. Symptoms are: Channels 3 and 4, 5 and 6 work as expected Channels 1 and 2 are not working at all either through DMX signal or though the manual control on the pack The linking bar is my first point of call, Is there anything else I should be looking for when on site? Cheers Quote backSTAGE Theatre Supplies LTD Specialists in Lighting / Staging / Consultancy Link to comment Share on other sites More sharing options...
KWR88 Posted May 9, 2008 Report Share Posted May 9, 2008 I think I spoke to you about this and the problem has been solved. If not please contact me on keith.rogers@cooperindustries.com Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
gjk513 Posted March 16, 2010 Report Share Posted March 16, 2010 Sorry for hi-jacking this thread but as i have an identical problem and thought I would keep the topics contained. I have no channel 5 and 6 on my Betapack. I have tried resetting the linking bar, checked the switches are on and flashed the channels manually is there anything else I can try? Quote Link to comment Share on other sites More sharing options...
soundesk Posted January 17, 2012 Report Share Posted January 17, 2012 Hi I have the same problem with channels 5/6. Wot was the out come? Quote Link to comment Share on other sites More sharing options...
KWR88 Posted January 18, 2012 Report Share Posted January 18, 2012 Can you pm me on the address below, with the dimmer serial number and I cna go through some things to check. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
