RW Posted December 13, 2007 Report Share Posted December 13, 2007 As you can tell by the many posts, I have had time to play with our frog 96. When setting the speed and fade up or step etc on the chase setup menu the chase will not speed up until you come out of the chase setup window, this can be a pain if you are trying to match the speed to a track. (I was running the beta version but I am sure that the same thing happens in normal software update??) Quote HARLOW COLLEGE Performing Arts. Link to comment Share on other sites More sharing options...
