twohats Posted September 12, 2007 Report Share Posted September 12, 2007 A few channels on our Betapack dimmers flicker when the output is at or near zero. The effect is influenced by the output on other channels, it can also be reduced or eliminated by raising the level of the flickering channel to 10 or 20%. I was considering adjusting the preheat pots, would this be a good idea? Robert Quote Link to comment Share on other sites More sharing options...
KWR88 Posted September 14, 2007 Report Share Posted September 14, 2007 My best guess is a fault with the low voltage rail being dragged around and causing the ref rails to be pulled down as well. this could be a problem with the output of the transformer or possibly the 470uF smoothing capacitors on the low voltage supply rail. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
twohats Posted September 21, 2007 Author Report Share Posted September 21, 2007 Thanks for that. As soon as I can I'll get a scope on the supply rails and see what they look like. Quote Link to comment Share on other sites More sharing options...
