Fat Frog - Multiple Chases on a single Submaster...
sjtown
Hello all,
Is it possible to run several Chases from one Submaster? :P
Can you either transfer multiple chases from the memories to a single submaster, or is it possible to do it another way, such as transferring each chase to a separate submaster then raising the chases on the submasters and programming another submaster from the chases running from the now transferred submasters?
I'm trying to choreograph lights to music with out it getting to complicated as I have very little time to spend programming!
last time I did this I put each chase for each group of lights on different submasters meaning it had to move many submasters at the same time!
If anyone's got any ideas or just a simple 'No' that would be great! :)
Cheers!
Steve
No :D
A submaster can be programmed directly with channel data OR it can have a single transferred memory which can be a scene memory or a chase.
Providing it is acceptable for the chases to have the same modifiers (direction, attack, drive, speed) could you not just program all the data into a single chase ?
Bran Media | Myspace
