sjtown Posted June 18, 2006 Report Share Posted June 18, 2006 Hello all, Is it possible to run several Chases from one Submaster? Can you either transfer multiple chases from the memories to a single submaster, or is it possible to do it another way, such as transferring each chase to a separate submaster then raising the chases on the submasters and programming another submaster from the chases running from the now transferred submasters? I'm trying to choreograph lights to music with out it getting to complicated as I have very little time to spend programming! last time I did this I put each chase for each group of lights on different submasters meaning it had to move many submasters at the same time! If anyone's got any ideas or just a simple 'No' that would be great! Cheers! Steve Quote Link to comment Share on other sites More sharing options...
K-Nine Posted June 19, 2006 Report Share Posted June 19, 2006 No A submaster can be programmed directly with channel data OR it can have a single transferred memory which can be a scene memory or a chase. Providing it is acceptable for the chases to have the same modifiers (direction, attack, drive, speed) could you not just program all the data into a single chase ? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
sjtown Posted June 19, 2006 Author Report Share Posted June 19, 2006 Thanks! I have very little time to programme so its easier to do the different chases separately so its not so taxing on the brain! Cheers, Steve Quote Link to comment Share on other sites More sharing options...
