Izzy Posted February 26, 2006 Report Share Posted February 26, 2006 hi I work with a leap frog in a nightclub. Rigged to it i have 10 clay paky stage light 300(16)... upgraded lately and we use partial mode... My problem is this... fixture 8 and 9 have a slight delay from the rest... in all the attributes... everything else works fine.. Thanks in advance Quote Link to comment Share on other sites More sharing options...
KWR88 Posted February 27, 2006 Report Share Posted February 27, 2006 I would start by checking the DMX connections are all ok. If not already done make sure the line is terminated correctly. Something that I would also do is set the DMX address on the lights to that of a working unit and see if the problem is present. Not sure about this as I do not have a full info set on the lights but some of them have motor option as part of the set up check that these are the same for all the lights. It may be an actual setting on the lights or and again I am not sure but the fx1 channel may do this. Quote Regards, Keith Rogers keith.rogers@signify.com DD: +44 (0) 1633 833 101. Link to comment Share on other sites More sharing options...
