Search the Community
Showing results for tags 'segmentation V7.7.0'.
More search options
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
    • Operator Database
    • ORB & ORB XF
    • Solution & Solution XL
    • FLX
    • FLX S24 & FLX S48
    • Dimmers
    • Network & Data Distribution
  • Product Support - Software
    • ZerOS
    • ZerOS Apps
    • Fixture Library & Editor
    • Jester Range
    • Leap Frog 48 & 96
    • Frog 2
    • Frog Range MK1
    • Illusion Range
    • Other Discontinued Products
Categories
  • General downloads
  • ZerOS
    • Current
    • Legacy
  • Capture Demo Packs
Found 1 result
  1. Attempting to upgrade a Leapfrog 96 from ZerOS 7.3.0 to 7.7.0 a segmentation fault occured and the upgrade didn't happen. The debug file that was added to the USB install stick is attached. An MD5 check on the downloaded zip file was the same on a second download so I assume that the download is ok. Every so often the desk fails to boot locking up with all 3 keyboard lights on, the frogs still jumping but nothing else happening. Usually a second attempt works. Could there be a connection? I have never had a problem with previous upgrades. installdebug.dat
