Search the Community
Showing results for tags 'Load fixture types failed'.
More search options
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
    • Operator Database
    • FLX S24 & FLX S48
    • FLX
    • Solution & Solution XL
    • Dimmers
    • Network & Data Distribution
  • Product Support - Software
    • ZerOS
    • ZerOS Apps
    • Fixture Library & Editor
    • ORB & ORB XF
    • Jester Range
    • Leap Frog 48 & 96
    • Frog 2
    • Frog Range MK1
    • Illusion Range
    • Other Discontinued Products
Categories
  • General downloads
  • ZerOS
    • Current
    • Legacy
  • Fixture Library
  • Capture Demo Packs
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Found 1 result
  1. Hi, Thanks for the explanation of the ORB XF at the booth in Frankfurt! After the demo in Frankfurt I wanted to play a little with the Phantom OrbXF, but unfortunately I always get the message "Load Fixture Type failed". Please see the attached jpg for details This also appears starting other versions. Curios: It worked before! Ok., I always had the problem that I could not close the application, I had to "kill" it by terminating the process via task manager. I tried a lot to get it run, changed the installation path, run as admin, changed the directory in the settings, reinstalled the application, cleaned the registry (at least what I found) etc. Nothing works. The hardware and software I'm using is a Lenovo Thinkpad T400 with Windows7 32bit, everything with the default MS windows drivers and up-to-date regarding patches etc. Regards Christian PS: I updated the "real" LeapFrog48 yesterday to 7.6 and tested it - without any problems. Runs perfectly.
