Search the Community
Showing results for tags 'Fixture Type Editor'.
More search options
  • Search By Tags
  • Search By Author
Content Type
Forums
  • General
    • News & Announcements
    • General Discussion
    • Operator Database
    • ORB & ORB XF
    • Solution & Solution XL
    • FLX
    • FLX S24 & FLX S48
    • Dimmers
    • Network & Data Distribution
  • Product Support - Software
    • ZerOS
    • ZerOS Apps
    • Fixture Library & Editor
    • Jester Range
    • Leap Frog 48 & 96
    • Frog 2
    • Frog Range MK1
    • Illusion Range
    • Other Discontinued Products
Categories
  • General downloads
  • ZerOS
    • Current
    • Legacy
  • Fixture Library
  • Capture Demo Packs
Found 1 result
  1. Hello and Good Morning from Canada I received 2 used YISCOR CREE 12LED RGBW LED Moving Heads. I was not able to find a similar match to that fixture with the new version 30 of the fixture profiles I downloaded the other day. I tried to create one based on the DMX Values chart provided on line but does not seem to work when I load it into my Fat Frog console. Below are the DMX values listed.... Channel DMX Value Function --------- ------------ --------- 1 000-255 X 0-540° 2 000-255 Y 0-180° 3 000-255 X Fine 0-1.8° 4 000-255 Y Fine 0-1.8° 5 000-255 Dimmer (0-100%) 6 000-255 Strobe (0-100%) 7 000-255 Red (0-100%) 8 000-255 Green (0-100%) 9 000-255 Blue (0-100%) 10 000-255 White (0-100%) 11 000-255 Mixed Colour Change -------------------------------------------------------------------- 12 000-011 No Effect 011-120 Jump Change 121-180 Gradual Change 181-244 Mixed Colour Effect 245-255 Sound Active -------------------------------------------------------------------- 13 000-255 Adjust CH12 effect speed fast to slow 14 000-255 Pan/Tilt Speed adjust fast to slow 15 245-255 Reset More info and fixture can be seen at the following address: http://www.ebay.com/itm/YISCOR-CREE-12LED-RGBW-LED-Moving-Head-Spot-Beam-Stage-Party-Light-DMX-Lighting-/141436177572 Any help creating this profile would be awesome. Thank You in advance for your .time. Rejean Frenette Toronto, Canada
