Days Won
34
Everything posted by Jon Hole
Hi techbppac and lxkev, I've recently taken over the software development of ZerOS. I'd like to try and explain what's going on 'behind the scenes'. As you saw at PLASA, ZerOS 8 was a massive update (with well over 200 issues and new features), and was far from being ready for release. We've learnt that there was just too much in this single release which then had knock on affects on other areas of the operating system, and kept pushing back the release date. We are now scaling back a release, called 7.6, which is the fastest, and most stable release of ZerOS I have seen in my almost 3 years here. However, stability is THE most important thing, so we are spending longer than normal testing this release, both internally and externally on shows around the UK and Europe. We are *so* close to releasing 7.6. After that, we are going to be working on Tracking Backup, as this is an area our current customers have told us they would like us to work on further. Once these areas, which are most important to our current end users, have been completed, we are then going to revisit the new features we want to release, as 'ZerOS 8'. I hope this gives you some insight into the incredible amount of internal beta software releases that's going on here at Cooper Controls, and I really hope you're going to be as happy with 7.6 as I am. We're always looking for new Beta Testers from a variety of backgrounds, and if this is an area of interest to you, please drop me an email. If you have any questions, please don't hesitate to contact me directly - all my details are in my signature below. Best Regards,
Move on dark stopped working when inserting a ‘cue only’
Jon Hole replied to keredyelesob's topic in Solution & Solution XL
Unfortunately this isn't quite the case. We are looking at a way we can cleverly get around this in software, however we need to ensure we don't then cause other issues that are unpredictable to the end user.- 4 replies
- Move on dark
- inserting a cue
(and 1 more)
Tagged with:
Hi, Thanks for this. We are currently trying to move server, because of these (and more) problems that we are unable to fix on the current server. It's a very annoying and frustrating situation at the moment, but in the next week or two we will be on new servers which we will have full access to, so we can fix these problems. Best,
Thanks for this info John - topic pinned
Kam 1000 3d laser programming issues
Jon Hole replied to Reverbjunky's topic in Solution & Solution XL
Hi, Please can you send me a copy of your showfile? My email is in my signature below -
Hi, It sounds like the close contact connection is staying connected (is the pedal latching? It needs to be 'push to make'), or possibly connected until you press the pedal instead of the other way around. Are any of those possible? Regards,
We are indeed! This is already listed as issue ZOS-4946. There's no time frame for a release yet.
Hi, The ORB XF has MIDI Timecode, allowing you to trigger cues against a timecode, for example on a projection or audio track. We are looking at implementing other MIDI functions in future software updates, but I don't have a time frame for this yet. These include MIDI Show Control and MIDI Notes Regards,
Hi Dan, Best way to alter a step of a chase is to 'load' it into the programmer, make the changes, and then 'Update'. It's not a glitch that we are aware of, however if you would like to send me your showfile, and which version of ZerOS you are running, I'm happy to have a look through it for you.
This sounds like a good option - create a chase on a submaster which does just the colour. Once you have got to the end of the chase, record several cues all the same - this gives you time to then pull down the submaster at the end, so the chase doesn't start again (there is no way to do a one-shot chase on a Jester ML). Because colour is 'latests takes precedence' (LTP), and submasters on the Jester ML don't release, the colour will stay when you pull down the submaster. Just make sure the intensity of the LEDs are recorded into the cue itself.
Hi, Sorry - your original post must have got missed in the post-Christmas catchup! This is happening because, using ‘Cue Only’, ZerOS is programming hard values into Cue 4, and hence the moving light is doing a live move. Do you have a showfile that you could send us? Regards,- 4 replies
- Move on dark
- inserting a cue
(and 1 more)
Tagged with:
Hi DickM, First, I was going to suggest recording several cues (I would personally use the point cues, so your number sequence doesn't get too badly affected), all with their trigger set to 'auto', and a fade time of however long you require. However, on a Jester, the following becomes tricky... If you know you have 10 cells, you could reduce/increase the percentage of each channel by 1/10th of the overall change on each step - however this isn't a 'nice' solution, and if you choose to make an edit of the final step, you would need to update each and every cue. It would work, however it's not an elegant, or particularly practical, solution!
We can definitely look further into this. I've added it as issue ZOS-5187 I've not had any experience of these, however other users on the forum might have done. We're looking into this, to ensure features are spread across our consoles in a logical manner! However, I don't have a time frame for you at the moment, sorry.
Hi Piero, MIDI Notes is currently only available on the Leap Frog 48 & 96, and the Solution Series at the moment.
Hi Johnny, When enabled, the first note relates to memory one, second to memory two etc etc. With 'Octave' enabled, each octave will do the same thing, meaning you can only access Memories 0 - 11. With 'Octave' disabled, the second octave will start from memory 12 onwards. Hope this helps,
Hi Charles, When the console has these problems, please save a copy of the show, and email it to me. Please also include the Serial Number of the console in the email. Many Thanks,
What version of 'Co Processor 1' are you running? This should get updated with the software update, but it's possible it was skipped. SETUP > Files > Desk Information
Try going into SETUP > Desk Setup > Event Monitor Now, push one of the problem faders right to the top of the travel, and you should see a load of text appear on screen at looks like this (with the blanks filled in). Fader 0x____ (_________________), New Level 0xFF, Old Level 0x__ Check that the last (bottom) line of text has 'New Level' as '0xFF' Now pull the fader to the bottom, and check that 'New Level' is at '0x00' on the last line of text. Repeat this for all the faders that are causing problems, and let us know the result. (to exit this window, you need a mouse or touchscreen to click the cross in the top right corner of the screen. If you don't have either of these, turn off the desk and turn it back on).
Hi Johnny, Yes - go to SETUP > Desk Setup and change 'MIDI Notes' from 'Disabled' to 'Channels', 'Submasters' or 'Memories'. Hope this helps,
The showfile will be absolutely compatible unless you are updating from a VERY old version of software, which it doesn't sound like you are (so long as your software is 7.x.x you'll be fine). Remember that updating the software wipes your showfile, so take a backup of the showfile onto a separate USB memory stick first, so you can load it back onto the desk
Hi Charles, Which version of software are you using? Please ensure you have the latest version of ZerOS installed, which can be downloaded here: http://zero88.com/support/index.php?/Knowledgebase/Article/View/366/172/
The same file will work across all our consoles
Hi Webbo, Several of our customers have had success using USB emulators (I can't confirm where these units came from) but this isn't something that we can directly support or be responsible for.
Zero 88 Fixture Library Release 25 For full information, please visit: http://zero88.com/software/library This release contains 3220 fixtures from 199 different manufacturers. For a list of fixtures in the library please click here. The library is released in 2 formats: a full unfiltered version for desks running ZerOS software (ORB Series, Solution series, Frog 2 and Leap Frog 48 & 96). a smaller filtered version for other Zero 88 desks. This removes data that is not used by these other desks, so that the file is smaller. When using a floppy disk (original Frog series, Illusion500) it is recommended that the floppy disk be freshly formatted before copying the library onto it. Download & Installation The correct format of the library for your desk can be downloaded by clicking the product name below. The files are zipped, and must be unzipped before they can be used. If you experience problems using the built-in zip file functions of Windows XP, then try Winzip. The library (.ift file) should be placed in the root directory of the floppy disk or USB stick. ZerOS desks (ORB Series, Solution series, Frog 2 and Leap Frog 48 & 96) The latest fixture library is automatically installed on the desk as part of each operating software update, however this can be updated from USB if required in Setup -> Files -> Update Fixture File. JesterML & JesterTL The fixture library is installed on the desk at manufacture, however this can be updated from USB if required in Setup -> Update Fixture Lib -> Update Library. Frog Series and Illusion 500 The fixture library should be copied to a floppy disk. Diablo The fixture library is used with the Diablo Fixture Manager PC software. Sirius 250/500 Use the Fixture Type Editor to import fixture types from the fixture library, and then use the ‘Export Sirius UFT’ function (under the ‘File’ menu) to generate data in the correct format for the Sirius 250/500. Further details of assigning fixtures on the desk to fixture types in the fixture library can be found in each desk’s operating manual. Additional Fixtures If you need a fixture type which is not in the library, then you can create this yourself using the Fixture Type Editor. If you post a link to the manufacturers datasheet on the forum, we will endeavour to add the fixture in the next library release.
