Days Won
34
Everything posted by Jon Hole
Hi Adrian, AUX buttons are available on the Jester 12/24 and Jester 24/48, but not on the Jester ML Series. You could create an 'ON' and 'OFF' palette for this, or you could create a submaster. You can download the manual from the link below, and all the information you need on palettes can be found on page 37 onwards. http://zero88.com/products/consoles/jesterml48/
Hi Joe, The Jester ML has support for 30 fixtures via the Multi Function Keys, but no additional dimmers, so we couldn't add syntax entry to access dmx channels onto that console. Best regards,
Hi Johnny, Are you aware that holding down SHIFT + COPY will allow you to transfer states between Memories and Submasters? That's the closest equivalent on the Leap Frog 48. There's no way to transfer a chase across to other channels, but you can create an effect on the Intensity parameter, which can then be applied to any section of channels. You can select the intensity channels by holding down SHIFT whilst pressing the flash buttons of the channel fader.
Hi Jack, We will require a letter on headed paper, including where you bought the console, and the serial number of the console. We will then reply with an unlock code. You can either email this, post it or fax it through to us. If you e-mail my colleague Keith Rogers as this would be the quicker option. His mail address is keith.rogers@cooperindustires.com Best regards,
Hi Lee, You can either upload it directly to this thread, or you can send it to me using http://www.yousendit.com or dropbox. My email is in my signature
Hi Lee, Please can you send us a copy of the showfile so we can look into this further? Many Thanks,
Mhled 3641Z Fixture File Not Working
Jon Hole replied to Teis Karstens's topic in General Discussion
Hi Teis, Is the Pan and Tilt working correctly on the fixture? I've had a quick look through your file, and it all looks fine. -
Hi Carwyn, PhantomZerOS, which is our offline editor, can be downloaded here: http://zero88.com/support/index.php?/Knowledgebase/Article/View/366/156/ The Windows Remote Monitor, which allows you to view the desktops of a ZerOS console on the same network, is available here: http://zero88.com/support/index.php?/Knowledgebase/Article/View/342/0/zeros-remote-software Hope this helps,
Hi piero, We're a bit confused on this one, your thread says 7.6 but the debug says you are running 7.1 of the ZerOS operating system. This is an issue that was fixed quite a while ago, so please update to 7.6: http://zero88.com/software/zeros Best regards,
Hi All, All the 'behind the scenes' work has been completed on our Community Support Forums - thank you for your patience whilst we've been sorting this out. If there are any questions, or you find any problems, please let us know. Best regards,
Over the next few days, we will be conducting essential maintenance on the Zero 88 Support Forum. We hope this will solve our current CAPTCHA issues for new users, along with many other problems. During this time the forum might not be accessible. If you have any urgent issues, please email support@zero88.com or call us on 01633 838088. Once this maintenance has been completed, certain elements of the forum will be reset, such as the skin we use. Please bear with us while we reinstate all these features back onto the forum, and fit them in with our new website. Many Thanks,
Hi Christian, Yes! We'll be in Hall 11 on Stand D40 and Hall 9 on Stand D51. There will be several of the Zero 88 team there, split across the two stands, so please come and introduce yourself! Best regards,
Hi Oliver, No we don't have any dust covers for the Jester range I'm afraid. Best regards,
We occasionally hear from users who are struggling to upgrade their ZerOS consoles via a USB stick. Bootable USB devices are notoriously difficult to identify - some USB memory sticks are natively bootable, others take a little configuration, whilst some cannot be made to boot. We recommend the use of the Zero 88 branded memory stick which is supplied with the console - this stick has been tested for this purpose and our software is built around these sticks. If you cannot use the branded memory stick, there are a couple of things you can try: In the USB Install Maker, when you're on the Select Device screen, push and hold SHIFT whilst clicking the Next button: The USB install maker will ask you to select OK to confirm you wish to set the Master Boot Record. Note that this can render some USB sticks unusable, so only use this if you have a dedicated stick for software upgrades. Select an MBR Image ( start with A, if that doesn't work, try B ) Push OK and your stick will be formatted - the tool will then prompt you to remove and reinsert the stick. After this, try running through the normal upgrade procedure and the stick should work as expected.
Hi Marc, This problem seems to happen on some PCs, and not on others! I find that closing the small 'control' box first (leaving the monitor and console windows open) generally closes the whole programme much quicker. There is a few seconds delay, as the programme closes down 'safely'.
Hi Marc, Looks like you've found my post explaining 7.6 - but I've included it below for reference. We're still working on ZerOS 8 - but as you can see, there were a lot of bug fixes and we wanted to get them out to you as soon as possible! We included some small but nice new features in there too which will hopefully really speed up programming. As always, if you have any questions please let me know
Zero 88 are pleased to announce the launch of ZerOS version 7.6 software - a major new software release for ORB Series, Solution Series, FROG2 and Leap Frog 48 & 96 consoles. More information can be found at http://zero88.com/software/zeros A full list of changes are available in the Release notes. If you have any questions, please don't hesitate to contact us at the office. Out contact details are: email: support@zero88.com phone: 01633 838088 Best Regards,
Hi All, We have released Version 7.6 - more information can be found in this thread: http://zero88.com/forum/topic/6495-zeros-software-76-released/ Best Regards
Hi Rob, the part number for a Sirius 500 wheel is 1198099 and it lists at £34. You should be able to buy this through your local Zero 88 dealer.
If you would like to request support for a new touch screen, please see this thread: http://zero88.com/forum/topic/6494-compatible-external-touch-screens/
We're looking to update our list of Touch Screen monitors that are supported within ZerOS. Do you have a preference of touch screen that we do not yet support? Please let us know if you would like us to add support for your touch screen. Our current list can be found here: http://tinyurl.com/ae8gbpj Many Thanks,
Hi Piero, Perfectly clear - thank you. I have added this as ZOS-5245 Regards,
Dear All, Today we are releasing ZerOS 7.6 RC (Release Candidate). As usual, this is a pre-release build of ZerOS, so we do not recommend using it on live shows without prior testing. You can download the USB, ISO and Phantom versions of it here: /// link removed due to software being publicly released /// USB - for ORB Series, Solution Series, Leapfrog 48/96 and Frog2 (New Hardware - one usb port on the front) ISO - for Frog2 (Old Hardware - two usb ports on the front) Phantom - 'Offline' PC software for Windows Best Regards,
Dear All, Today we are releasing ZerOS 7.6 RC (Release Candidate). You can find out more information here: http://zero88.com/forum/topic/6491-zeros-76-rc-release-candidate/ Best Regards,
