Stateside Moving Light
Everything posted by Stateside Moving Light
  1. Hi, Thanks for the reply, we used the CD to update after burning the iso file, I have now managed to load a older version 6.0 but we still have the LCD problem. It was working fine befor update but after updating LCD firmware it all went wrong The LCD is blank and only the time in the bottom right is just visible. By using shift screen I can move screens to it but they are barely visible and there is a hum bar running from bottom to top.
  2. Hi All I have an old Frog 2 with 2 usb ports on front (010) I have just tried to update this to latest version of Zeros 7.7.0 It was a disaster! loads of failed updates. and no way back. went back and put 6.0 on and now LCD screen is unreadable, lots of lines moving from bottom to top and screen is very very faint as if the contrast is all the way down, you can just make out frog 2 on the screen then some squares. I am taking it that the older versions are not compatible with new OS Can someone confirm this. Any ideas about LCD screen
  3. Hi All I have an old Frog 2 with 2 usb ports on front (010) I have just tried to update this to latest version of Zeros 7.7.0 It was a disaster! loads of failed updates. and no way back. went back and put 6.0 on and now LCD screen is unreadable, lots of lines moving from bottom to top and screen is very very faint as if the contrast is all the way down, you can just make out frog 2 on the screen then some squares. I am taking it that the older versions are not compatible with new OS Can someone confirm this. Any ideas about LCD screen
  4. Thanks Peter for the reply, we are agents for Windirect & Longman light our website is www.statesidelightandsound.co.uk for windirect and http://longman-light.com for longman. We have just finished using the FRog 2 on two sunday shows at Her Majestys in London. That was the only problem we had. Phill
  5. Would it be posible to have a reversed dimmer on a fixture that would work 0-255 dmx = open-closed. I have found some China manufactures have this as normal but when making a profile for them in the editor I cannot use the master fader. Perhaps this is alredy possible to do, if any one can tell me how please contact me.
